Straight Cut Primary Bush
15 replies to this topic
#1 MIJ
MIJ
  • 74 posts
Posted 08 August 2019 - 07:11 PM
Is it correct the bronze bush inside the primary gear (back one) can rotate inside the primary gear itself?
#2 DeadSquare
DeadSquare
  • 1,564 posts
  • Local Club: Herefordshire Motor Club
Posted 08 August 2019 - 07:18 PM
No
#3 Moke Spider
Moke Spider
  • 9,405 posts
Posted 08 August 2019 - 08:38 PM
Just so we are on the same page, the back one is the top hat shaped one.
That one shouldn't - no.
#4 ACDodd
ACDodd
  • Mini Docs
  • 2,214 posts
Posted 08 August 2019 - 11:57 PM
The front one unless it's a fully floating type will not spin, the rear, top hat one should not spin.
Ac
Edited by ACDodd, 08 August 2019 - 11:59 PM.
#5 MIJ
MIJ
  • 74 posts
Posted 09 August 2019 - 12:19 PM
Thanks guys. I've received a minispares one and the top hat one is spinning within the gear itself.
#6 MIJ
MIJ
  • 74 posts
Posted 09 August 2019 - 04:48 PM
Sorry guys getting confused.
Pic below of bush that is spinning. It's the one under the gear itself.
The other side under the spline is fixed
#7 Moke Spider
Moke Spider
  • 9,405 posts
Posted 09 August 2019 - 06:51 PM
Before jumping in to anything too far here, have you got a link or part number of the gear you actually purchased?
#8 MIJ
MIJ
  • 74 posts
Posted 09 August 2019 - 07:03 PM
Hi Spider This is the one I purchased
https://www.minispar...30.aspx|Back to
#9 Moke Spider
Moke Spider
  • 9,405 posts
Posted 09 August 2019 - 07:34 PM
According to the info on their webpage with that, it should be a fixed bush in that one.
#10 MIJ
MIJ
  • 74 posts
Posted 09 August 2019 - 07:39 PM
Thanks Spider, can you lint me in the direction to the info? I can't seem to see it
#11 imack
imack
  • 823 posts
Posted 09 August 2019 - 07:48 PM
I thought all the minispares straight cut primary gears used the floating bush these days although it's not mentioned in that add, still showing it for the 998.
Looks like the bush is retained by a circlip in your picture, thats normally a floating bush. I have the minispares 22 tooth sc evo primary, it has a floating bush.
#12 ACDodd
ACDodd
  • Mini Docs
  • 2,214 posts
Posted 09 August 2019 - 09:49 PM
It's the floating type, it has the steel clip fitted which keeps it in place.
Ac
#13 Moke Spider
Moke Spider
  • 9,405 posts
Posted 10 August 2019 - 12:56 AM
Scrolling down the page it has this;-
The DAM8889 is a fixed standard bush.
#14 imack
imack
  • 823 posts
Posted 10 August 2019 - 07:48 AM
Best call minispares to check.
#15 GraemeC
GraemeC
  • 5,312 posts
Posted 10 August 2019 - 09:53 AM
The website is obviously out of date.
The one you have in your picture has the circlip there for has the floating bush.  It should turn in the gear.
Mini Spares
