Anyone any experience? There seems to be a couple of options:
MED Timing Cover (https://www.med-engi...am-timing-cover) you need to re-use your timing plate or MED also sell an alloy timing plate.
RetroSport (http://www.dsnclassi...front-breather/) allows you to eliminate the timing plate?
If you add the alloy timing plate to the MED kit then the price of both are identical.
I'm running the Swiftune vernier duplex timing gear set.
