I have a few machines and now, I doubt I'd be able to function without them.
While you may have small ambitions presently, I guarantee once you start with something like this, any limitations will be quickly found and be quite frustration.
The machine aside, even half decent tooling to go with it will cost a bit too.
My advice here is get the biggest and heaviest machine you can afford both on terms of money and space. The machine will not only work better, and with improved repeatability but will also last much longer. I'd suggest something around the 750 kg mark as a starting point.
I'll add that small light machines like the one you are contemplating are frankly a waste of money.
If you can afford a half decent machine, then seriously, buy a decent drill press (floor mount) and then any machining work you need to have done get done 'outside'.
