Hello,
I am wondering if a A series pinion crownwheel set will fit on an A+ mainshaft? About to offer it to a friend but do not know if it will fit.
Thanks,
Paul
Posted 11 August 2019 - 08:06 AM
Hello,
Thanks,
Paul
Posted 11 August 2019 - 08:25 AM
Pretty sure it will, but by all means wait for a second opinion from someone that's actually done it.
Posted 11 August 2019 - 08:42 AM
Cheers. Can't get the mainshaft nut undone at the moment. And I am on the heavy side too!!
Posted 11 August 2019 - 08:50 AM
As pairs yes, they interchange.
Posted 11 August 2019 - 09:26 AM
Have you got a big break-away torque wrench ?
If you use one that you can knock the square drive through, screw it up to its max and use it in reverse; as it breaks away, it acts like an impulse wrench.
Posted 11 August 2019 - 10:48 AM
Edited by floormanager, 11 August 2019 - 10:49 AM.
Posted 11 August 2019 - 10:49 AM
Posted 11 August 2019 - 04:47 PM
Brilliant thanks Moke and Deadsquare. Glad an A series fits. I'll give the torque wrench a go. My breaker bar just bends
Just checking, which gears are you locking up? Should be 1 and 4.
Rattle guns are also good for undoing very tight nuts.
Posted 11 August 2019 - 04:56 PM
This is how I do it:
Posted 11 August 2019 - 05:35 PM
Posted 11 August 2019 - 05:36 PM
Posted 11 August 2019 - 05:40 PM
Posted 11 August 2019 - 06:39 PM
They will go in but make sure both are either A+ or pre A. You can’t mix them as you’ll not get the diff cover back on.
Thanks for the advice. There's a 3.44 A+ on there at the moment but my mate wants to do rallying and his mates are telling him 3.4 is too high. I have an A series 3.6 crownwheel and pinion but until I get the main nut off I cannot try it. Need a big, heavy german car to sit on it!
Paul
Posted 11 August 2019 - 06:41 PM
Paul
Posted 11 August 2019 - 11:33 PM
Edited by timmy850, 11 August 2019 - 11:33 PM.
