Float In Carb
4 replies to this topic
#1 grahama
grahama
  • 2,442 posts
Posted 13 August 2019 - 04:45 PM
Does this look ok?? Is there anything missing that the hole in the plastic float should have in?? Or does the float self adjust to stop fuel flow??Attached File  93A7B771-8F2E-46DB-845B-42DD377B603F.jpeg   20.68K   1 downloads
#2 Chris1275gt
Chris1275gt
  • 1,052 posts
Posted 13 August 2019 - 10:16 PM
If the hole would allow liquid into the float No as it would fill with liquid and not float,just like a ball valve in any water tank, as the petrol pumps into the chamber and fills it the float floats on the top of the petrol and closes a small valve when it's full, when more petrol is burnt the float drops and allows it to fill again.
#3 nicklouse
  • 19,060 posts
Posted 13 August 2019 - 10:42 PM
if that hole allows the float to fill it is Fubar. if it is only on the top part is it how it was made and is a replacement.
#4 Rorf
Rorf
  • 866 posts
Posted 14 August 2019 - 06:25 AM
First question to ask is does the float chamber flood over when the petrol pump is operating. Something looks odd though and I would suggest pulling the float pin out then remove the needle valve assembly, and post another photo of the top of the float.
#5 grahama
grahama
  • 2,442 posts
Posted 14 August 2019 - 11:02 AM
No the chamber doesn’t flood over at all. It does’float’ as expected. I have seen them with a bendable metal strip to adjust them with but mine design have one.
I checked it as I was having a carb problem which turned out to be the jet height making the mixture extremely lean and when revved, fuel starved.
Just checking things now I have richened the mixture up.
