Anyone know where you can get the big wiring grommet which sits in the parcel shelf under the central speedo binacles? Actually I think the binacles are shaped to fit around it. Can't find it or a part number for it.
Elusive Wiring Grommet
Posted 16 August 2019 - 06:48 PM
Posted 16 August 2019 - 07:45 PM
I think this is the one you're talking about is says 1 5/8" http://www.leacyclas...com/2h2065.html
Posted 16 August 2019 - 08:07 PM
Could well be thanks, I'll try measuring it. I'm not removing the wiring so will have to cut the grommet, fit it and restick it somehow.
Posted 17 August 2019 - 04:05 PM
This is the grommet:
It had been cut in order to fit it but is now deteriorating:
The hole in the parcel shelf is a slightly odd size at 1.73".
Someone must sell these, you can get just about everything else.
Posted 17 August 2019 - 07:34 PM
When looking around for grommets, I've found these days there's (proper) rubber ones and there's PVC or 'plastic based' types.
The rubber ones are really good and these are what I use when I can find them in the size I'm after.
The 'plastic based' types I find dreadful things, they are very hard, and difficult to fit. Some off questionable cable protection.
Posted 17 August 2019 - 10:01 PM
People must need these fairly often, I'm just suprised that I can't find it listed in the Minispares parts manual and can't find it searching their website.
Posted 18 August 2019 - 06:36 AM
Thanks, that'll do the job. I must ask Minispares why they don't sell one.
I'll have to cut it to fit it and then re-stick it together. What's best to use which won't damage the rubber?
Posted 18 August 2019 - 06:47 AM
Posted 18 August 2019 - 07:17 AM
https://uk.rs-online...ubber-grommets/
As said above, don't go for plastic grommet. It's crap
Posted 18 August 2019 - 10:27 AM
Posted 18 August 2019 - 10:36 AM
Part number RFR210 plug, dash panel and hole in dash.
Ooo could be, I'll ask them when I'm there.
Posted 22 August 2019 - 09:01 PM
Well the website picture looks about right http://www.minispare...sic/rfr210.aspx but then they brought one out more like this for a 3/4" hole https://www.autospar...e-size-3-4.html
I told them what I wanted it for and they said they don't supply that one; marvellous.
Edited by unburntfuelinthemorning, 22 August 2019 - 09:02 PM.
Posted 23 August 2019 - 11:13 AM
