Here's the spec:
1330 block, about 1700 miles since rebuild
Compression spec'd at 10.5:1
Head: JonSpeedRacing 12g940 with 35.5 / 29 mm valves (came with short block package)
Cam: SW5
Intake manifold: Minispares
Carb: hif44, BCE needle
Air intake: round airbox with K&N round filter with 4 1" holes drilled
Dizzy: fast road electronic (similar to Aldon yellow)
Exhaust manifold: Freeflow
Exhaust: RC40 twin box
Rockers: 1.3 ratio minisport
Fuel ratio also shown on chart - operator (experienced, but not with mini specific knowledge) said mixture looked really good.
I'd expect the peak torque to occur closer to 5k rpm, and the HP curve to climb to 5500 rpm or so on an A+ series, right?
Is the drop of in torque / HP over 4k due to head limits? Exhaust restriction from freeflow manifold, other?
Edited by macaldron, 18 August 2019 - 10:29 PM.
