Guys, as above, have the option of so called Van tyres (I believe they are trailer tyres) or "normal" saloon car tyres. They are radials (I am told) I have the standard 3.5" *10" steel wheels. Are the so called "van" tyres legal on a car in the UK, or should I just fit the Standard saloon tyres. The car is a 998 standard in everyway drums all round 1981 Pickup, I am seeing the rear tyres side walls cracking presumabley due to age and weight, as it did spend 4 hrs at 60 MPH on the motorway to Bristol fully laden, and after that the side walls looked a little tardy. So was just thinking would Van tyres on the rear be a better option, and indeed are they legal ?
Tyres 145 * 10 On The Rear Of A Mini Pickup
Posted 20 August 2019 - 09:28 AM
Posted 20 August 2019 - 09:41 AM
you don't need "van" tyres on a pick up as the max load it can carry is way less than the normal rating of the road tyres.
Posted 20 August 2019 - 09:56 AM
Hi Nick,
I agree they are not needed from a weight point of view. I was thinking more along the lines of longevity as the tyres are likely to be worn out via age well before the tread is used up (I do very little mileage). The Van sidewalls are much stronger, I am told, so in theory might last longer, but I am not sure on the legality of them.
Posted 20 August 2019 - 10:13 AM
I have not seen 145 x 10 van tyres, so be sure that they arenot some sort of buggy tyre and not for road use.
There are very few 10" tyres now available and for a Pick-Up a normal 145/80 x 10 should be ideal.
Posted 20 August 2019 - 10:30 AM
Hi Nick,
will not last any longer the rubber will just go off at the same rate.
Posted 20 August 2019 - 10:42 AM
cheers guys, I think the "normal" 145 / 10 tyre it is then
Posted 20 August 2019 - 12:22 PM
I sourced the tyres from the Black Circle website, the tyres were shipped directly to the fitters, I'd went along and spoken to them regarding fitting price (Got the fitting cheaper as the wheels were brand new Cooper wheels)
Edited by cal844, 20 August 2019 - 12:22 PM.
Posted 20 August 2019 - 12:51 PM
I have Falken Sincera (145/80/10) tyres on my Clubman Estate, I never have a heavy load on the car so I use 28psi front and 30psi rear.
and they have a load rating of 325kg each so 4 will do a pick up and its load easy.
Posted 20 August 2019 - 02:22 PM
Cheers guys much appreciated
Posted 20 August 2019 - 03:16 PM
Yes that's correct with the load rating, they're good tyres for dry and wet conditions aslong as they aren't pushed too hard.
Posted 08 February 2021 - 12:46 PM
Moved to a separate tread ;) in Chat Section
https://www.theminif...aybe/?p=3683431
Edited by MiNiKiN, 08 February 2021 - 01:08 PM.
