Engine Stand?
1 reply to this topic
#1 Bobbins
Bobbins
  • 1,344 posts
Posted 21 August 2019 - 10:57 AM
Is there a "standard" way that an A-Series engine is mounted on an engine stand? I've only ever used my stand when rebuilding K-Series units which are mounted from the flywheel end, with the A-Series most seem to be mounted from the dizzy side but which drillings are used? Not sure whether it's relevant but it'll be an MPi that I'm working on.
Stu.
#2 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,017 posts
Posted 21 August 2019 - 11:10 AM
The carb and SPI blocks are pretty easy to hold by using the alternator and oil filter housing bolts and making an adaptor plate. The MPI's look a bit more difficult to hold but you should be able to use four of the bolts on the front with an adaptor plate.
