I would like to install the following rocker cover on my SPi JSpec Mini. Please advise where I should connect the hose out of it. Thanks. rocker cover.jpeg 54.23K 3 downloads
Rocker Cover
Posted 21 August 2019 - 01:16 PM
Posted 21 August 2019 - 09:24 PM
The hose on the cover is not standard. Looks like a flexible brake hose where the cover has been drilled and then fixed to it.
Posted 22 August 2019 - 05:21 PM
Posted 23 August 2019 - 07:22 AM
Just keep in mind, the filter may allow oil vapours through
Posted 23 August 2019 - 07:39 AM
Connect it to the air cleaner.
Posted 23 August 2019 - 01:59 PM
I have a similar style cover from the 60-70s and they included a breather pipe on the top (yours appears to be a brake line like Jon stated). These were intended to connect to the air cleaner housing on carb cars. The injection cars have a pretty unique "sealed" breathing system for Minis. All the breathers feed back into the throttle body. You would have to find a way to splice into that system OR slap a filter on it and let it vent into the atmosphere. I think blocking it off and getting a new vented cap would be ideal though.
