Flip-Front / Removing The Front End.
Posted 21 August 2019 - 10:18 PM
I’d like to remove my front end (Clubman) and turn it into a flip front using the same removed end (A-Panels staying attached to car).
Is this possible or do the front ends get damaged when removing?
With the a-panel/wing weld, is it just a case of drilling the spot sells on the seam?
Or if anyone wants to post an idiot proof guide on how to do it, feel free!
Cheers!
Posted 21 August 2019 - 10:34 PM
This is really not a good idea.
It reduces the structural integrity of the body-shell and makes it much less crash-resistant.
It reduces the value of the car.
Posted 21 August 2019 - 10:42 PM
I’m not fussed about the value, I’ve owned the car forever and doubt I’ll ever sell it anyway. The car will be used for hillclimbs and sprints etc, a removable front end is just easier.
Posted 21 August 2019 - 11:11 PM
loads of spotwelds to drill out. what you doing with the inner wings?
Posted 22 August 2019 - 08:13 AM
It is on road cars that full monocoque structure is needed as the front body structure needs to be able to take crash loads as originally designed.
Posted 22 August 2019 - 08:34 AM
Yes, you can drill out the spot welds and release the wings from the body, if you have a right angled drill, it is handy in places, but for rigidity, you will have to weld, rivet or screw the wings and the bonnet together, and weld tabs to the A panel to locate the wings.
Posted 22 August 2019 - 11:12 AM
....assuming it is held together as it left the factory which isn't very likely. Certainly drill what spots you can find, but have a clear preference for which panels you want to save when you have to get less surgical.
Posted 22 August 2019 - 01:54 PM
It’s actually on its original doors, boot, bonnet, wings and a-panels, only big problem I’m seeing is the seam at the top of the wing and scuttle panel, my brother welded and smoothed it over many years ago, so I don’t have that natural line to follow.
Posted 22 August 2019 - 01:55 PM
Losing a chunk of each inner wing as I’m fitting a K-series.
Posted 23 August 2019 - 06:50 PM
I agree with Cooperman, it's not a great idea. What about settling for a carbon fiber bonnet? They actually Come with a mod for K séries i think.
I am also all about light Weight mini but a flip front is something I won't do.
Plus from what I heard, it's a nightmare to fit properly. :)
Only my 2 (euro) cents.
