I'm looking at a 1972 morris mini 1000, but the engine number both in the V5 and on the block shows 328455, which is not consistent with the regular engine numbering.
Apart from this, the engime seems to be stock, no mods either on the engine or car itself.
Any ideas if this is a proper number ?
Thanks.
Engine Number - 6 Digits?
nospamprl
, Aug 23 2019 05:53 PM
6 replies to this topic
Posted 23 August 2019 - 05:53 PM
Posted 24 August 2019 - 12:51 PM
if it’s just numbers, probably just an engine builders random number, unusual not to have full number, is it a full width engine plate, or has it been cut? Photo would be helpful. At least it matches v5. Someone will hopefully chime in with what the engine number should be no doubt.
Posted 24 August 2019 - 06:33 PM
This is the picture
Posted 24 August 2019 - 06:50 PM
Is that a gold seal engine (or silver seal)? They had various numbering systems
Posted 24 August 2019 - 07:38 PM
Have no idea.
Posted 24 August 2019 - 07:45 PM
Here are some pictures
Posted 24 August 2019 - 08:21 PM
what ever that engine plate is, it is not factory, quite telling as the numbers are stamped IN, rather than stamped from behind, and therefore raised letters like the factory ones.
