Hi
i had an issue before with the front spot lamp there was an sound from the internal switch like (Electric petition)hen the spot lamp switch stopped and not working now!
A month later I am trying to start the car, the start motor working fine but the engine not start.
i bring the acr4 to test the fuel pump and give me no error. I changed the (ecu, mems, fuel filter, coil, checked the fuses) with no change happendز
the fuel pump not give me sound like the past Just vibrate at first. my friend tell me maybe you have miss connection for the fuel pump and that's why the pump not working well and not get a 12v.
also I opened the fuel hose from the front and switch on the ignition no fuel come out. any body know how I can check the fuel pump line and if the spot lamp line may linked with the fuel pump line.
is the spot lamp issue effected the fuel lamp?
note: the fuel pump is new not old.
highly appreciate if anyone can help me and tell me what to do
