1975 850 Rebuild
Posted 29 August 2019 - 09:15 AM
I have a shell, and nothing else, that needs full restoration so needs everything bought and adding back to it so just wondering if there's any where I can get full technical specs from as well as information on original colour and styling. It's been off road for 12 years or so from what I can make out from the information I have
Posted 29 August 2019 - 10:47 AM
https://www.britishm...ge-certificates
Posted 29 August 2019 - 11:37 AM
http://www.minipassi... range 1975.pdf
http://mk1-performan...k/pdf/74-75.pdf
Not sure if a Heritage Certificate will tell you the original colour -recorded information was minimal to say the least during the 70's.
Check out places like inside the rear wheel-arch for traces of original paint.
Edited by Itsaminithing, 29 August 2019 - 04:54 PM.
Posted 04 September 2019 - 08:58 AM
The first link didn't work for me but thanks for the info on the trim colours
Posted 04 September 2019 - 10:02 PM
Bit odd -i'm having the same issue, never had a problem with that site before.
http://www.minipassi...s/brochures.htm
The 1974 Mini Range brochure still works.
Posted 05 September 2019 - 12:27 PM
Any idea what type of rear subframe I would need as well?
Posted 05 September 2019 - 01:37 PM
Comments I would make regarding other features in addition to the rust ...
Fixed back single colour vinyl seats.
Single centre speedo, no other gauges.
Two spoke bus steering wheel.
Rear subframe standard dry type, same as currently available.
