1998 Cooper Sport 5
18 replies to this topic
#1 lenfish
lenfish
    Starting My Mini Up
  • 2 posts
Posted 02 September 2019 - 06:17 PM
Hi all,
I bought a mini some time ago and I'll be honest, I don't know a great deal about them. I've been doing some research to try and find out if there is anything that makes my mini rare or unique. In my googling I found out that they were normally fitted with 4 speed gearboxes whereas I always made the assumption that they all came with 5 gears + reverse. Mine has 5 gears and I've never driven any other Coopers so had no reason to think otherwise. Can anyone give me some more information on 1998 minis that were fitted in with 5 speed gearbox?
#2 cal844
cal844
  • 9,736 posts
  • Local Club: TFMOC
Posted 02 September 2019 - 06:34 PM
I think the 5 speed gearbox is aftermarket, I know that minispares.com have the 5 speed gearboxes but they are expensive. It could be that someone has fitted one of these, I'd suggest looking through any receipts you have recieved with the car
#3 Spider
  • 15,878 posts
Posted 02 September 2019 - 06:56 PM
There's some debate as to whether these gearbox were fitted on the factory production line or not, but they were a factory sanctioned model.
If I recall, they were sold through John Cooper Garages, there were only very small numbers of them.
The gearbox itself was done by Jack Knight and so sadly these days, parts are for the most part, NLA.
There were a few other trick bits unique to this model.
#4 DeadSquare
DeadSquare
  • 3,382 posts
Posted 02 September 2019 - 06:59 PM
At least 1/2 the Minis are unique, because owners do things to them.
Rare minis are early ones.
#5 mab01uk
mab01uk
  • 13,085 posts
Posted 02 September 2019 - 07:58 PM
Here is an ad for one with photos:-
http://www.gcminis.c...-sport-5-14-995
#6 beardylondon
beardylondon
  • 1,814 posts
Posted 03 September 2019 - 06:36 PM
Moke Spider is correct, Cooper Sport 5 was a Rover approved special edition, sold only through John Cooper garages for a limited time.
Some info here, and yes they are rare.
https://www.minicoop...ooper-register/
#7 Guest_minidizzy_*
Guest_minidizzy_*
  • Guests
Posted 03 September 2019 - 11:44 PM
The Cooper S Sport 5 was available only from John Cooper Garages from 1997 and, if genuine, should have a plate screwed to the floor cross member to the right of the driver's seat with a unique number. It also had Cooper Sport 5 decals replacing the Mini Cooper laurels. Ideally there should be certificate in the paperwork.
The engine was tuned to give 85 bhp (from 63 bhp). Other features were a 5 speed gearbox, Rover sports pack extras, walnut interior fittings, alloy door furniture, alloy fuel cap, alloy dip stick, Si boot badge, John Cooper leather gear knob. There was an option of leather seats.
#8 rich_959
rich_959
  • Just Joined
  • 568 posts
Posted 04 September 2019 - 07:17 AM
:lol:  Ha ha. Oh the negativity.
#9 CityEPete
CityEPete
  • 3,920 posts
Posted 04 September 2019 - 09:17 AM
Wasn't the BHP a bit optimistic if I remember rightly?
#10 r3k1355
r3k1355
  • 585 posts
  • Local Club: East Anglia
Posted 04 September 2019 - 03:45 PM
Yea but no great surprise really, pretty common for the era.
It's the Cooper Upgrade kit, decent enough stuff.
#11 DeadSquare
DeadSquare
  • 3,382 posts
Posted 04 September 2019 - 04:01 PM
It inspired me to try and fit 5 gears into a Mini box.
#12 Spider
  • 15,878 posts
Posted 04 September 2019 - 07:21 PM
One other feature to check for on these cars is the Gearbox Case. Apart from being a 5 speed, the cases were uniquely cast and should have the following features.
The Casting No. on the casing, while being a DAM5626, also includes JKD initials
also, on the bottom, there's 2 bolt heads
My good friend Dave Rosenthal did 6 - with a sequential shifter - does that count?
#13 mk1leg
mk1leg
  • 9,343 posts
Posted 04 September 2019 - 07:46 PM
we have 2 JCGs minis with 5 speed boxes fitted they are very nice to drive
Edited by mk1leg, 04 September 2019 - 07:46 PM.
#14 DeadSquare
DeadSquare
  • 3,382 posts
Posted 04 September 2019 - 09:34 PM
 Yes, I went down the motorcycle route and got as far as ascertaining that the cogs would fit
The first problem is that they don't have a reverse gear.
The second is that most motor cycle gear boxes drive in and out at the same end. but the BMW K has the input and output at either end, so that seemed a good start.
 It uses a 3 shaft system, so the input could be extended to a reverse gear cluster, and a bonus was that I was told, erroneously, that 5th was a 1.6666 overdrive.
It turned out that 5th is a reduced 1.6666, which means that the transfer gears have to be used to bring it back to 1:1, and that entails chopping and changing the transfer case.
I thought that my "prototype" had been destroyed in a barn fire, but about a month ago when rummaging in some boxes, I found it.
#15 Guest_minidizzy_*
Guest_minidizzy_*
  • Guests
Posted 05 September 2019 - 12:26 AM
It probably was optimistic. The later S Works kit was claimed as 90 bhp, which was at about the limit for the ECU, but I don't think anyone achieved that. The upgrade from the 85 bhp kit to S Works was a new LCB manifold and a modified air filter assembly.
