Boot Badge Position
8 replies to this topic
#1 Bobbins
Bobbins
  • 1,526 posts
Posted 04 September 2019 - 08:59 PM
Can anyone with a Mk3 tell me how far the boot badge is down from the top lip of the boot ... I have the badge but no holes!
#2 Bobbins
Bobbins
  • 1,526 posts
Posted 05 September 2019 - 05:53 AM
Anyone?
#3 imack
imack
  • 2,382 posts
Posted 05 September 2019 - 06:28 AM
Can check this evening for you
#4 imack
imack
  • 2,382 posts
Posted 05 September 2019 - 02:43 PM
As fitted to an original 72 boot lid.
#5 Bobbins
Bobbins
  • 1,526 posts
Posted 05 September 2019 - 02:50 PM
That's perfect, a big thank you :)
Same boot badge as well!
Edited by Bobbins, 05 September 2019 - 02:51 PM.
#6 Tornado99
Tornado99
  • 750 posts
Posted 28 September 2020 - 05:35 PM
I have a "1275" badge from MiniSpares that I'd like to place on the boot lid of a 1988 Mini (originally a 1000 but now has a 1275 after restoration). Can anyone provide a rough location where is should go?
#7 imack
imack
  • 2,382 posts
Posted 28 September 2020 - 07:59 PM
This may help, genuine bmc mk2 boot lid with factory drilled badge holes.
Unfortunately I can't get to the back of the car at the moment to take measurements.
#8 Tornado99
Tornado99
  • 750 posts
Posted 29 September 2020 - 11:50 PM
Thanks that matches an image I found on Google images so I can guesstimate from there.
Found a 3M product called Press in Place Adhesive which is specifically for badges and emblems. No cutting out the tape to fit the lettering as it is a series of small sticky dots that come off the backing where lettering touches. Brilliant. No holes to drill.
https://www.3mcanada...94780474&rt=rud
Edited by Tornado99, 29 September 2020 - 11:50 PM.
#9 Tornado99
Tornado99
  • 750 posts
Posted 10 November 2020 - 11:03 PM
Just an update: I just placed my "1275" badge on the boot lid, to the right of the license plate surrounds as per the image linked earlier. I used the 3M Press-in-Place adhesive backing...first time with that stuff. It really seems to do the trick, no trimming around the badge shape and no fussing. I needed to trim off the little prongs on the badge that are meant to insert into holes in the body panel (which I didn't want to make). Used a dremel cut off disc for this and went smoothly. Time will tell if the adhesive holds up OK....though it is made specifically for this purpose.
by the way, I got 10 sheets of the the Press-in-Place stuff in the packet I bought ($8 cdn locally)....so if anyone needs a bit maybe I can help you out....
