Welding Aluminium soaks up filler rod, unlike steel or braze, and being able to feed it smoothly and fast enough is a knack that takes time to lean, and if you only weld ally occasionally, the knack sort of evaporates.
Welders Of The Forum. What Tig?
#16
Posted 09 September 2019 - 10:19 AM
#17
Posted 09 September 2019 - 02:52 PM
#18
Posted 10 September 2019 - 11:52 PM
#19
Posted 11 September 2019 - 09:21 AM
Get a Big bottle, tig welding is slower going, so you'll use more especially till you get the hang of it. Also get a reg with a flow meter on, it'll pay for itself in one bottle...
Also if your looking at the rent free bottles, check the charge pressure, it can make a big difference to the cost/gas ratio.
Edited by mini13, 11 September 2019 - 12:17 PM.
#20
Posted 27 September 2019 - 04:26 PM
Just been looking at https://www.r-techwe...r-rods/?cat=305
#21
Posted 27 September 2019 - 04:44 PM
#22
Posted 27 September 2019 - 05:20 PM
#23
Posted 28 September 2019 - 02:03 PM
Some 2.4mm 5356 rods will do you for all your general purpose welding of catch tanks and what not.
Just a thought. Say making a catch tank. What thickness of sheet are they generally made from?
#24
Posted 28 September 2019 - 02:25 PM
I made a 2L dry sump tank for a Honda engined custom bike out of 2mm aluminium sheet and that was plenty strong enough.
#25
Posted 28 September 2019 - 04:24 PM
I don't mean to question your skill, but for a learner, probably best not to go below 3mm
#26
Posted 28 September 2019 - 06:09 PM
Thank you for not answering the question.
#27
Posted 28 September 2019 - 11:08 PM
#28
Posted 29 September 2019 - 08:52 AM
#29
Posted 08 October 2019 - 02:07 PM
ohhhh there are different materials for the electrodes.
and different sizes.
it seems to be a bit of a science to be getting started.
#30
Posted 08 October 2019 - 02:39 PM
Yes, and the angle at which you grind it and if you ball the tip.
Like all these things, you can get by with some basics but it you're aiming for 'stacked dimes' then these little things make all the difference.
I'd recommend watching the YouTube videos by 'This Old Tony', he goes into a lot of this and welder settings too.
