I have watched them already. missed the bit about the different electrode materials. He really should organize them a bit better.
and then the grinding.
Posted 08 October 2019 - 02:45 PM
Posted 08 October 2019 - 08:28 PM
Posted 08 October 2019 - 08:45 PM
nice one. currently i will be sticking to 2mm and maybe 1mm sheet alloy. and some thin steel and some 1.5mm steel
anything else will be much later stainless and other exotics i have no need at the moment.
Posted 08 October 2019 - 10:27 PM
Posted 09 October 2019 - 08:34 AM
yep, 1.6 and 2.4's, you'll only need the 3.2's if your doing thick plate, like 5mm+
I found that for most ally work 2.4's work best, as with the cleaning action you get more heat in the tungsten and the 1.6's cant handle it, maybe that just me.
Also for stainless work i get on better with 1.6's, thats on 1.5mm tube for manifolds,
get a couple of packs of tungstens, and sharpen them all, to start with you will be dipping the tip and swapping them out a lot, especially on ally, on steel you can get a way with a little dip, on ally/AC it just turns straight to a black mess....
there are handy settings apps for phones too, Ive got the Miller app on my phione, gives a good ball park setup to get started from.
Posted 09 October 2019 - 09:28 AM
interesting my local welding supplier does not have 2% lanthanated (blue) only 1.5% lanthanated (gold) might look further at other places to see if it is the same.
Posted 09 October 2019 - 01:45 PM
got to love Ebay. a selection of filler rods ordered and two sizes of Electrode ordered. why two length of electrodes though. had to go out an measure. came with 150 but 175mm will easily fit in the long holder.
whats the deal with the torch "sizes"? (not the shrouds i get them).
Posted 09 October 2019 - 02:32 PM
the electrode length are for torch varients, normally you have the "long" cap on the back that the electrod extends into, buit for tight spaces you might want to swap this for a short/flush cap and shrt electrode,
toprches are generally for fifferent ampages, the Wp17 is the most common, and fine for most useages, if your doing fine work then somthinng like a wp9, or if your doing heavy stuff a wp26, theres probably sizes in between too. also theres flex head torches for really contorted spaces.
electode wise, theres been a move away from thoriated tungstens as they are midly radioactive, and grinding them has health concerns. apart from that its a topic of much discussion, and really its best to just get some of each and see what you like best. its been a while since ive welded, and cant remember what i was using now.
Posted 25 October 2019 - 07:57 PM
Well had a day playing with thin sheet steel 1mm as I had it around and it was not going to be used for anything.
really quite interesting.
will be playing with some alloy tomorrow.
Posted 26 October 2019 - 07:52 PM
Mmmm too many knobs to really get my head around it today with alloy welding.
fusing corners together with no filler early looks great and looks ok with quite some depth on the inside. Going to take some time this alloy stuff. But dropped the torch and snapped the long rear cap. So a rest day tomorrow.
Posted 26 October 2019 - 08:08 PM
If you just snapped the back off fill the hole with epoxy putty and use it as a short cap for confined spaces.
Break and electrode to length and off you go again.
Did you get a foot pedal with your kit?
Posted 26 October 2019 - 08:59 PM
Posted 26 October 2019 - 09:37 PM
You'll get there... the foot pedal will give you so much more control.
Posted 26 October 2019 - 10:09 PM
