Headlamp Wiring.
3 replies to this topic
#1 Minigman
Minigman
  • 779 posts
Posted 06 September 2019 - 05:06 PM
I what to change from standard 70’s headlights which have a 40/45w lamp to cibie H180 kit with 55/60w H4 lamps.
Do I need to to upgrade the wiring and install relays for the additional amps or can I just use the existing as it’s only a 1.5A increase?
#2 nicklouse
  • 18,679 posts
Posted 06 September 2019 - 05:08 PM
If you are not losing voltage through old worse you will be fine.
#3 Bat
Bat
  • 903 posts
Posted 06 September 2019 - 07:58 PM
Hi,
Standard wiring will cover it, just check you're getting the same voltage at the headlights as you are at the alternator.
Cheers :)
#4 andyapanel
andyapanel
  • 625 posts
Posted 07 September 2019 - 12:50 PM
I think you should keep an eye on the light switch. At the very least, carry a spare switch and loom repair kit.
If possible upgrade to a relay; I can recommend "Wired by Wilson"'s product.
Good luck; it is nice to be able to see at night.
