Posted 07 September 2019 - 10:26 AM
Posted 07 September 2019 - 10:42 AM
Simplest would be an inlet manifold air leak. Check hose connections and the slacken and retighten the nuts.
Posted 07 September 2019 - 11:30 AM
I sprayed around the inlet with some carb cleaner but it didn't seem to do anything
Edited by Zak Jones, 07 September 2019 - 11:31 AM.
Posted 07 September 2019 - 10:03 PM
If there's an air leak engine side of the throttle it'll allow proportionally more air in when less air goes through the closing throttle and the manifold vacuum increases.
After market manifold flanges can be a different thickness to the original making it harder to clamp both inlet & exhaust together.
Since it's injection, an air leak on the exhaust side could do similar by affecting the lambda sensor, but you'd probably hear that.
Posted 08 September 2019 - 10:12 AM
Posted 08 September 2019 - 12:30 PM
Milky Oil In Rocker After Not Draining Water Before Removing HeadStarted by jezjsa , 11 Mar 2024 engine |
Speeduino EcuStarted by cooperpooper , 09 Mar 2024 electrical, engine |
Mini Now Wont StartStarted by jezjsa , 25 Feb 2024 engine |
Rough Running On Standard CoilStarted by Sweep16 , 09 Feb 2024 electrical, engine |
Duplex Timing Chain Sprockets Alignment IssueStarted by Timrobins , 22 Jan 2024 engine |
