Is there a trick to fit the reverse light switch on rod change?
I put the gear lever In reverse, the screwed in the switch. I connected a test light across the switch so I knew when I had it screwed in far enough.
The light came on when the switch was screwed a long way in. However I could not get the lever out of reverse!! I had to screw the switch out to free the lever. It is as if the plunger in the switch was not contacting what ever it should.
I have A Mini manual & also a Metro manual , but neither mention the reverse light switch.
any advice would be appreciated.
I'm just wondering if the Yoke (or eye) inside the shifter is up-side-down ?
Might have to remove the plate on the bottom to have a look to see what's going on here.
Hi Moke
I have never driven this car, so it is possible something may have been assembled incorrectly! The yoke hangs down below the change rod, but could this be installed back to front? The. Manual is very poor so I cannot see if there is a right way or a wrong way for this to go in.
anyone got any photos?
That is the correct way around.
While you have the cover off, wind in the switch and you might be able to see what's fouling it.
It maybe that you are selecting 4th Gear as AlasdairM has suggested. You can always tell when you have selected reverse with a Rod Sift Box as it make a very distinctive tap / clunk sound that is totally different to all the other gears, that pretty much make the same sound. You do need to lift the stick to get it in to reverse, though, if you have the bottom plate of the shifter off, you won't need to.
