Installing Oil Gallery Plugs
3 replies to this topic
#1 mark205gti
mark205gti
  • Just Joined
  • 39 posts
Posted 09 September 2019 - 02:33 AM
I have removed the oil gallery plugs (x4) from the block during my rebuild. I am now about to install back in new oil gallery plugs (12G3503 solid type from minisport).
They seem pretty tight. I was planning on just hammering them in with a punch. Is this ok or should they be pressed in? Or should I get the non-solid 12G3503 brass from minispares, or just tap the holes m14x1.5 and install grub screws?
#2 Spider
  • 15,845 posts
Posted 09 September 2019 - 07:29 AM
Solid plugs that are a tight fit can be an issue. They can (and usually do) 'broach' on the block as they are going in. In doing so, there's a small chance some swarf can end up in the Main Oil Galley. They do need to be a tight fit and I do fit them with Loctite, not just to hold them, but also to assist with sealing.
The Pressed Plugs are better in this regards.
It's also a good idea to 'stake' the holes to retain the plugs if they should want to go for a walk, with either type of Plug.
I personally prefer Screwed Plugs.
#3 DeadSquare
DeadSquare
  • 3,382 posts
Posted 09 September 2019 - 09:11 AM
I re use the old ones, gormmed with Hylomar.
I drill 2/3 deep into one of the plugs and tap it 1/4" to insert a bolt to pull it out, then knock the other out with a rod.
Before re inserting, I give them a smack on the anvil with a lump hammer to swell them.
There may be 80 psi in the gallery, but the plug face is only fractions of a square inch, so there is only about 15 lb pushing on it.
#4 grizzler73
grizzler73
  • 300 posts
Posted 09 September 2019 - 10:07 PM
I tapped mine and grub screwed (M14 I think?!), but my engine will be rebuilt pretty regularly
