Towing A 1977 Mini On A Tow Frame, After Market Eye Bolts?
15 replies to this topic
#1 2kwrx
2kwrx
    Starting My Mini Up
  • 2 posts
Posted 11 September 2019 - 10:39 AM
Hi guys, my wife has a 1977 Mini that we want to tow quite some distance behind a ute. We have purchased a towing frame which I am having modified to fit the width of the towing eye bolts on the Mini. I have heard that the standard eye bolts are “made of chocolate” and will not be strong enough for the job, so I am looking for after market ones. Can anyone recommend specific ones that would handle a rigid tow frame? Some I have seen online say “only for rope towing”, then there are aluminium ones, but would they have enough strength? Any advice greatly appreciated.
Kevin
#2 nicklouse
  • 19,058 posts
Posted 11 September 2019 - 11:09 AM
as towing on an A frame in the UK requires the brakes to be connected and working it is not that common. also it is an easy way to trash a Minis Gearbox.
Back to your question never ever seen any. but some longer bolts (suitable grade) a spacer and some lifting eyes should be up to the job.
#3 DeadSquare
DeadSquare
  • 3,382 posts
Posted 11 September 2019 - 11:59 AM
Look at the markings on the head of the bolt, and look them up on gurgle.
In my youth, they were highish tensile.
#4 gazza82
gazza82
  • 3,099 posts
  • Local Club: TMF+
Posted 11 September 2019 - 01:08 PM
I think I'd be more concerned about the gearbox ... it's been discussed before and the concensus is "don't" ...
#5 MiniMadRacer
MiniMadRacer
  • 906 posts
Posted 11 September 2019 - 01:27 PM
Out of interest how would it "knacker" the  Gearbox,  unless its auto box?
#6 nicklouse
  • 19,058 posts
Posted 11 September 2019 - 01:31 PM
http://www.theminifo...-to-tow-a-mini/
#7 MiniMadRacer
MiniMadRacer
  • 906 posts
Posted 11 September 2019 - 01:47 PM
Thanks Nick, you learn (ok I learn) something new every day. I didn't know that, but it does make sense now - cheers
#8 DeadSquare
DeadSquare
  • 3,382 posts
Posted 11 September 2019 - 04:37 PM
Lots of impoverished racers used to tow their Minis to race meetings.
Some took out the plugs and stuck it in top gear and older engines were inclined to pump a bit of oil on the journey and needed a cloth held over the plug holes with a bungee,  but plenty of choke and N8 plugs usually worked to start them.
One chap, who used to strip his engine every week !, used to drive a wedge under the clutch arm.
Edited by DeadSquare, 11 September 2019 - 04:46 PM.
#9 2kwrx
2kwrx
    Starting My Mini Up
  • 2 posts
Posted 11 September 2019 - 07:23 PM
My Mini mechanic has advised that during the trip, we should regularly detach the Mini and drive it for a bit to protect the gearbox, so we will do that. Here in New Zealand it’s not a legal issue to tow the Mini on an A-Frame, it just becomes a trailer. So my only real issue is suitable mounting points for the A-Frame.
Kevin
Edited by 2kwrx, 11 September 2019 - 07:23 PM.
#10 CityEPete
CityEPete
  • 3,920 posts
Posted 11 September 2019 - 08:45 PM
Could you get some kind of skate made instead, front wheels up and strapped down to something with it's own wheels. I sure it would be nicer to tow and less chance of damaging the mini?
#11 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 11 September 2019 - 09:32 PM
A towing dolly would be perfect but a little bulkier than an A frame
#12 DeadSquare
DeadSquare
  • 3,382 posts
Posted 11 September 2019 - 11:05 PM
If it can be driven and you are prepared to drive it parts of the way, why can't you drive it all the way ?
#13 Rorf
Rorf
  • 866 posts
Posted 12 September 2019 - 05:27 AM
Remove the half shafts :lol:
#14 DeadSquare
DeadSquare
  • 3,382 posts
Posted 12 September 2019 - 06:27 AM
I think the wheels might come off that idea.
#15 MiniMadRacer
MiniMadRacer
  • 906 posts
Posted 12 September 2019 - 07:57 AM
I guess you could take the D shafts out and put "spare" CV joints back in the hubs to stop anyones wheel falling off and wheel
 bearings collapsing
