Intermittent Ignition/power Problem
3 replies to this topic
#1 1314cc
1314cc
  • 306 posts
  • Local Club: tumbleweedminisbristol
Posted 12 September 2019 - 12:09 PM
Ok, so I've new battery, main cable, new earths. The fault first occurred 6 years ago . Mini has been off the road since then. Finally im almost ready for a mot! So im experiencing an occasional complete loss of engine power and ignition lights go out . After grinding to a halt it starts up again. Could this be the ignition switch or the brown wire feeding off it?
Edited by 1314cc, 12 September 2019 - 12:36 PM.
#2 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 12 September 2019 - 12:49 PM
The lights should come on when power is off. Check and clean the connections at the fusebox, starter and ignition switch then go from there
#3 viz139
viz139
  • 727 posts
  • Local Club: Irish Mini Owners Club
Posted 12 September 2019 - 02:46 PM
If your power lose is limited to engine and ignition lights that would suggest the problem is in the white wiring. Wipers ,indicators ,horn hazards all still working.
I would first check the ignition switch and the connector at the steering column.
What year is the car?
#4 1314cc
1314cc
  • 306 posts
Posted 12 September 2019 - 04:37 PM
1989
I'll have to wait for it to occur the next time i've got it running to check the wipers etc .
