See if this helps
Posted 14 September 2019 - 07:30 PM
See if this helps
Posted 14 September 2019 - 08:01 PM
Thanks guys, will get back to it tomorrow. Anyone know if there should be a ground attached to a bolt on the left side of the alternator? It looks like there should be but there isn't.
Posted 14 September 2019 - 08:39 PM
The alternator earths through the engine block.
Posted 14 September 2019 - 10:21 PM
How about taking the fan belt off so the alternator is isolated and do a (very) quick run. If the noise goes then there's the culprit.
Posted 15 September 2019 - 09:14 PM
Posted 16 September 2019 - 03:24 PM
Belt tension and alternator bearings are mechanical noise you hear at the engine . The next thing I would do is run the engine without the alternator connected to ensure the interference isn't coming from the ignition. If it is clear and you have already changed the amp I would look at replacing the alternator.
Posted 16 September 2019 - 04:06 PM
Posted 22 September 2019 - 12:06 PM
Posted 22 September 2019 - 03:23 PM
Glad you're getting somewhere with it.
Posted 22 September 2019 - 05:49 PM
