Hi Lo's Ripspeed
7 replies to this topic
#1 cristiano1968
cristiano1968
  • 444 posts
Posted 12 September 2019 - 05:05 PM
Hello I've just got some minispares hi lo's ripspeed.
I see they've gor holes on the side .
Do I have to cover them up with tape to avoid water going in or should I leave them open?
#2 cristiano1968
cristiano1968
  • 444 posts
Posted 12 September 2019 - 05:36 PM
Attached File  20190912_191018-1-1.jpg   29.61K   4 downloads
#3 richmondclassicsnorthwales
  • 942 posts
Posted 12 September 2019 - 05:43 PM
You will find they are for lubrication I'm sure. Allows oil to be added to the threads, I can't picture the said HiLo trumpets, a while has passed since I last used a full set of the RipSpeed on a subframe build.
I religiously used to cover the threads of HiLo in grease before assembly. One thing you can do is use small rubber bungs to stop any ingress of water, but as long as there is oil or grease as lubrication, you should not hit any issues. Steel and aluminium don't mix very well with water
#4 richmondclassicsnorthwales
  • 942 posts
Posted 12 September 2019 - 05:46 PM
You have put a picture on while I was typing away.
I can see some grease there - so a good start - but you can use some rubber bungs if you like. Bleed nipple covers reversed is just an idea
#5 imack
imack
  • 2,381 posts
Posted 12 September 2019 - 06:19 PM
It's a water drain hole on my 80's type Ripspeed hilo's.
#6 cristiano1968
cristiano1968
  • 444 posts
Posted 12 September 2019 - 06:58 PM
Thanks ??
#7 NikOett
NikOett
  • Just Joined
  • 42 posts
Posted 12 September 2019 - 07:59 PM
I always thought that the holes were there so you could put a screwdriver in to prevent them from turning when adjusting the threads. In the case of the front ones the water would have to get to a pretty high level for it to work as a drain
#8 imack
imack
  • 2,381 posts
Posted 12 September 2019 - 08:20 PM
Don't know what the new ones are like but on my old allen key only adjusted ones that are pictured, the drain hole looks high externally but internally it is at the lowest point at the top of the internal screw thread.
Picture shows internal shape and why the drain hole appears so high.
Edited by imack, 12 September 2019 - 08:30 PM.
