Oil Pressure Gauge Pipe.
6 replies to this topic
#1 noeman
noeman
  • 125 posts
Posted 13 September 2019 - 10:51 AM
Hello,
I've just fitted a smiths oil pressure gauge and it seems to be working fine. 68lb on idle cold.
But I fitted the transparent pipe and noticed the oil doesn't go all the way to gauge, is this normal/Ok?
It seems to stop the last bit going up to the gauge on the dash.
Cheers for any insights.
Mark
#2 nicklouse
  • 19,058 posts
Posted 13 September 2019 - 10:54 AM
it is fine.
#3 jaysmini1983
jaysmini1983
  • 217 posts
  • Local Club: West Country Mini's
Posted 13 September 2019 - 11:41 AM
over time you may notice that the air will bleed out of the tube when the car is hot and running. but again dont worry. its pressure in the pipe that the gauge uses
#4 nicklouse
  • 19,058 posts
Posted 13 September 2019 - 11:50 AM
how? if it is you have a fault somewhere and it is leaking.
#5 noeman
noeman
  • 125 posts
Posted 13 September 2019 - 12:33 PM
I was being impatient, after a while when the engine warmed up it eventually went all the way to the gauge.
Thank you for your replies.
#6 unburntfuelinthemorning
  • 2,003 posts
Posted 13 September 2019 - 01:11 PM
I have always slackened the fixings at the gauge to bleed air out.  Seems to make the needle movement on the gauge smoother.
#7 MiniMadRacer
MiniMadRacer
  • 906 posts
Posted 13 September 2019 - 01:46 PM
Absolutely right Unburn, air compresses making the needle "jerky" until the air is fully compressed by the oil pressure, oil does not compress so gives  a smoother needle, but having said that, once the pressure is up the needle pretty much doesn't move anyway
