Now that this car is approaching 25 years of age (hard to believe that I've owned it for nearly half that time), I'm going through it and replacing a lot of wear components, old sensors, etc. The drivers side rear radius swing arm has excessive play so it is dtime for that . As long as I'm there, I guess I should consider what else to replace in the suspension. It rides pretty hard in my opinion as do all Minis but I suspect it has grown worse as the rubber hardens over time. What would you recommend replacing on the suspension? Rubber cones front and back? Shock absorbers too?
Thanks,
Paul
