Zerk Fittings (Grease Titty)
Best Answer sparkymae , 19 September 2019 - 11:06 AM
Took the zerk off and used a piece of wire to stick in the hole, then gently blew it out with a air gun. That did the trick.  Thanks Neil for the reply. :)
Go to the full post
5 replies to this topic
#1 sparkymae
sparkymae
  • 141 posts
  • Local Club: None
Posted 16 September 2019 - 12:09 PM
Hi all. Went to grease my front end on my 1990 Mini as i do on a regular bases. All went well until i got to the one on the right brake hub. RHD. Could not pump any grease at all in it. Replaced the zerk, (tit) 3X. still a no go. Backed the new one out a bit, still nothing. Anyone have any ideas, or has had this little problem. Thanks, Gary
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,188 posts
  • Name: Neil
Posted 16 September 2019 - 12:28 PM
Sounds like the grease pathway is blocked with hardened grease. So you will need to use a piece of wire or similar to see if you can clear the blockage.
You could use a airgun if you have a compressor to try and clear it that way.
I take it you have physically checked each of the grease nipples to ensure grease comes out of each of them?? And i mean by just inserting the nipples in the grease gun and try to pump grease through.
#3 DeadSquare
DeadSquare
  • 3,382 posts
Posted 16 September 2019 - 01:13 PM
Is the wheel off the ground ?
#4 sparkymae
sparkymae
  • 141 posts
  • Local Club: None
Posted 16 September 2019 - 01:46 PM
Yes, the wheel is off the ground. :)
#5 sparkymae
sparkymae
  • 141 posts
  • Local Club: None
Posted 19 September 2019 - 11:06 AM   Best Answer
#6 sonikk4
sonikk4
  • 16,188 posts
  • Name: Neil
Posted 21 September 2019 - 10:48 AM
No problem, it’s something we do quite a bit on Aircraft where we have have hundreds of grease nipples to deal with.
