One Wheel Is Further In That The Other
9 replies to this topic
#1 beardylondon
beardylondon
  • 1,791 posts
Posted 16 September 2019 - 07:48 PM
I have noticed that my newly acquired 1990 Cooper as one rear wheel about 18mm further inside the wheel arch than the other. One side you can get you hand in behind and the other you can't. I have had the wheels off shortly after I bought it and put new 165 tyres on with 3mm spacer both sides but it's clear to see. It drives fine and there doesn't appear to be any twisting in the shell or evidence of accident damage at all, is this good old Rover, or a dodgy radius arm or something perhaps?
#2 Tones61
Tones61
  • 441 posts
Posted 16 September 2019 - 08:03 PM
Bent radius arm,or radius arm bearing gone?
#3 Pops_Guild
Pops_Guild
  • Just Joined
  • 363 posts
Posted 16 September 2019 - 09:39 PM
As above sounds like bent radius arm, arm mounts or bearing gone. I had similar, caused the tyre to rub on the inside as I cornered right. Mine was caused by all three!
#4 1968andyf
1968andyf
  • 147 posts
Posted 16 September 2019 - 09:46 PM
Could also be bent or poorly mounted subframe. Some of the aftermarket one are poor quality
#5 greenwheels
greenwheels
  • 691 posts
  • Local Club: Mini Fixers
Posted 17 September 2019 - 08:38 AM
Is the front of the subframe parallel to the healboard?
#6 beardylondon
beardylondon
  • 1,791 posts
Posted 17 September 2019 - 05:56 PM
Thanks for all the suggestions, I’ll have a good look when I get a chance
#7 viz139
viz139
  • 727 posts
  • Local Club: Irish Mini Owners Club
Posted 18 September 2019 - 01:34 PM
Is there a spacer drum brake fitted on both sides. If its driving fine and no noticable tyre ware its unlikly to be a bent radius arm. Does the camber look the same on both sides?
#8 CityEPete
CityEPete
  • 3,920 posts
Posted 18 September 2019 - 05:05 PM
My first thought was one side without a spacer drum and one with.
#9 CityEPete
CityEPete
  • 3,920 posts
Posted 18 September 2019 - 05:06 PM
Could also be that the wheels have different offsets, check the markings on the wheels to make sure.
#10 beardylondon
beardylondon
  • 1,791 posts
Posted 19 September 2019 - 07:03 PM
Im pretty sure both sides looked the same when I had the wheels off, and I forgot to mention I added a 3mm spacers each side when fitting the new 165s, as per forum members suggestions. Camber looks good and I had it tracked recently too. I will double check wheel offset too.
