Burning Oil And White Smoke
Best Answer MiniMadRacer , 17 September 2019 - 10:55 AM
4 looks low...Dry to wet but yet its the highest over all which seems odd.... what colour are the plugs after the car has run up to normal temp?
Was / is your battery fully charged by the way ?
Go to the full post
#16
Posted 17 September 2019 - 11:17 AM
#17
Posted 17 September 2019 - 11:20 AM
If all plugs "match" colour wise I wouldn't have thought you have a "Gasket" issue, and figures to me suggest you don't have a Gasket issue.. interesting to see what others think
#18
Posted 17 September 2019 - 11:25 AM
#19
Posted 17 September 2019 - 11:45 AM
#20
Posted 17 September 2019 - 12:05 PM
I think the valves can do with a relap and the head decoked but see what someone else says
I know this may sound stupid, but what to you mean by relap?
#21
Posted 17 September 2019 - 12:47 PM
I would agree the figures do look ok with some potential piston ring/ bore wear on 3 and 4.
Several things here to look at. The carb itself, is it adjusted correctly?? possible bent needle, no oil in the dash pot, possible air leak making things go lean on initial acceleration?? All of these things can cause power issues along with timing.
Ref the valves. Re lapping is when you remove each valve in turn, look at the seat in the head and valve itself. If there are no signs of pitting etc, you then use grinding paste to lap the two surfaces together, the surfaces being the valve seat in the head and the contact face of the valve. When done correctly it should be a even grey finish.
If the valve seat shows signs of pitting / burning / damage then its time to have them replaced. The same applies to the valves. This is the time you also look at the valve guides for wear and of course the vale stem seals. Just to say doing it with a drill is quick but hand lapping will give you more leeway.
#22
Posted 17 September 2019 - 01:00 PM
I would agree the figures do look ok with some piston ring wear.
I have a new carb ordered, I will try that first before I strip down the engine, thanks for all your advice, I'll keep you posted on the result..??
#23
Posted 20 October 2019 - 03:35 PM
