Engine Balancing Needed?
7 replies to this topic
#1 MK1russ
MK1russ
  • 50 posts
Posted 16 September 2019 - 09:36 PM
I'm in the process of assembling a Pre A+ 1330cc block using a later CAM6232 crankshaft, A+ conrods, new +60 pistons and pre-verto standard flywheel that has been lightened & balanced. It crossed my mind today that as all of these components are from different engines, would it be necessary to have them all balanced together before installing them? Or would I be ok to carry on fitting them as they are?
#2 DeadSquare
DeadSquare
  • 3,382 posts
Posted 16 September 2019 - 09:48 PM
It's an opportunity not to be missed.
Do you know  Tyler Motorsport at Kingstone /Madley ?
#3 MK1russ
MK1russ
  • 50 posts
Posted 16 September 2019 - 10:51 PM
Yes i'm thinking while i'm here is it worth doing.
No i don't know them. The only place i've been using for machining work is Phoenix Rebore in Hereford but i'm willing to try someone that's more of an A series specialist.
#4 Bobbins
Bobbins
  • 1,526 posts
Posted 16 September 2019 - 10:56 PM
In the past (for K-Series parts) I've used Wilkinson Dynamic Balancing in Halesowen and been very pleased.
#5 DeadSquare
DeadSquare
  • 3,382 posts
Posted 17 September 2019 - 06:08 AM
Type "Tyler Motorsport" into gurgle, it should bring up a map.
If you go there, ask him to show you my downdraft S head and 48 IDA Webber.
#6 Dusky
Dusky
  • 5,322 posts
Posted 17 September 2019 - 06:14 AM
Technically no. Should all be balanced in their own already. But ideally yes especially if it needs to rev.
#7 MK1russ
MK1russ
  • 50 posts
Posted 17 September 2019 - 01:30 PM
You have a PM.
That's the other thing I'm thinking too, as all the components show their original balancing 'signs'.
I'm only building a torquey road based engine and I don't plan on revving it beyond 6k rpm.
#8 Bobbins
Bobbins
  • 1,526 posts
Posted 17 September 2019 - 02:28 PM
I've just fitted an MED lightweight & balanced flywheel/clutch assembly and it's removed a whole load of vibrations from the way it was previously. Not had anything else balanced but when the engine comes apart I'll be getting it all balanced properly.
