Mpi Rear Fog Lamp
3 replies to this topic
#1 bdean
bdean
  • Just Joined
  • 102 posts
Posted 17 September 2019 - 11:00 AM
Anyone got a picture of the rear fog lamp and mount for a 1997on Mpi? Mine is not as the ones listed in the parts catalogues.
#2 Bobbins
Bobbins
  • 1,327 posts
Posted 17 September 2019 - 11:34 AM
Look at Steve's page here: http://www.theminifo...k-turbo/page-39
#3 bdean
bdean
  • Just Joined
  • 102 posts
Posted 17 September 2019 - 12:26 PM
Mine looks like this!
Sort of like this one from Mini Spares but the mounting arrangement still does not look to be the same.
https://www.minispar...|Back to search
#4 Bobbins
Bobbins
  • 1,327 posts
Posted 17 September 2019 - 02:22 PM
I've just refurbished the rear of mine including fitting the Mpi fog light, that's why I knew there was a good photo on Steve's build thread. Mine's actually a JDM Mini and was fitted with a small square fog light on a one bolt mounting, not the same as your mounting but not dissimilar. The Mpi fog light and bracket are available from Minispares: (http://www.minispare...|Back to search You'll need to buy the light as well, or go on ebay and get an LED version: https://www.ebay.co....6IAAOSwjKtcZHu2
If you check the LH end of the valance there should be 3 holes with blanking grommets/plugs, 1 hole for a cable, 2 for a lamp bracket - these are identical to the arrangement on the RH side before it tried to rust away so should give you an idea of the mounting setup.
Stu.
Edited by Bobbins, 17 September 2019 - 02:25 PM.
