Boot Mounted Reverse Lamp: Early Mk2 Boot
6 replies to this topic
#1 b_artman
b_artman
  • 16 posts
Posted 19 September 2019 - 07:24 PM
Hi folks - I have what I believe is a 1968 boot lid which is the mk1 style / dual skinned (not the open webbing type) that is ready for paint. Before I do, I would like to also mount my rear mounted Lucas reverse lamp which I currently run on Mk4 boot. It would require drilling a hole in both layers and possibly using a grommet to cover the hole on the interior side. Any reaction to that? Am I stepping onto a sacrilegious landmine for cutting into this lid? Not sure how rare or in demand these things are.
#2 nicklouse
  • 19,055 posts
Posted 20 September 2019 - 03:10 PM
Ain’t there a hole already for the number plate illumination? Use that.
#3 GraemeC
GraemeC
  • 7,472 posts
Posted 21 September 2019 - 06:42 AM
Why would he want to mount a reversing lamp where the number plate lamp is?
It’s your car, drill the holes if you want. Some people may moan, but it’s not an irrepairable thing and there are still Mk2 lids around.
#4 nicklouse
  • 19,055 posts
Posted 21 September 2019 - 08:32 AM
Never said that. There will be a hole in the second skin where the wires enter the boot space. Use that hole.
#5 creakyjaws5533
creakyjaws5533
    My jaw needs oiling. Where's the WD40??
  • 1,195 posts
Posted 21 September 2019 - 09:20 AM
I think he means to actually tighten the nut up as he would need a much larger hole directly above the boot lamp to tighten it up
#6 Dr s
Dr s
  • 428 posts
Posted 24 September 2019 - 07:30 PM
If it’s what you want buzz a hole in it. It can be invisibly repaired. Probably best to go for a gap rather than a rib.
#7 Daz1968
Daz1968
  • 2,058 posts
Posted 24 September 2019 - 07:42 PM
I used to have a reversing lamp on my mk2 and I drilled through both skins and just secured it on inner skin, the large rubber washer sealed on the outer, not got it on now, but easy to weld in a patch if you align it away from a rib on inner.
