What Panel Do I Need To Buy?
5 replies to this topic
#1 PauljRawlings
PauljRawlings
    Just On Tickover
  • 6 posts
Posted 20 September 2019 - 05:02 PM
Hello Everybody, Can you tell me what panel I should by to repair this hole? Is it an inner wing?
Regards
Paul
#2 PauljRawlings
PauljRawlings
    Just On Tickover
  • 6 posts
Posted 20 September 2019 - 05:03 PM
I should add that I am going to replace the floor pans as somebody has jacked the car up by the lifting strap point and buckled the floor.
#3 minifreek1
minifreek1
  • 1,260 posts
  • Local Club: S.U.N.M.O.C
Posted 20 September 2019 - 05:40 PM
I think its called a flitch panel that you would need to replace, but it can just be patched for now for ease. To replace the flitch panel itself is quite a major repair as its not just the flitch panel that would need replacing but also the A panel and possibly the front wing on that side.
#4 PauljRawlings
PauljRawlings
    Just On Tickover
  • 6 posts
Posted 20 September 2019 - 05:49 PM
Thanks MiniFreek1 I guess I willl patch it for now.
#5 cal844
cal844
  • 9,486 posts
  • Local Club: TFMOC
Posted 20 September 2019 - 05:59 PM
Just make a simple repair panel that will flush weld into the area, put a right angle on the bottom to tie into the floor pan
#6 PauljRawlings
PauljRawlings
    Just On Tickover
  • 6 posts
Posted 21 September 2019 - 09:37 AM
I guess I should cut out the rot back to good metal first andthen weld in the panel. Other side is probably as bad so I guess I will do both at once.
Spentthismorning chipping of inches of seam sealant and underseal. It was thicker than i'd expected in places.
