Posted 22 September 2019 - 07:51 AM
And is it safe to reuse this brake pad?http://imgur.com/a/SUpoCKm
http://imgur.com/gallery/Uf3Sass
Posted 22 September 2019 - 09:24 AM
I would replace them for the cost involved and their importance.Just want to share a picture of a greenstuff pad i removed today. Is this a fault in the manufacturing of normal ware.
Posted 22 September 2019 - 09:46 AM
Also check for sticky piston. Looks like over heated.
Replace... would not want friction surface to dislodge and take you off the road..
Posted 22 September 2019 - 01:22 PM
Posted 22 September 2019 - 03:05 PM
Always tried to avoid them like the plague.
Posted 22 September 2019 - 03:30 PM
Normally when they get hard use before going through a few heat cycles. But it still shouldn’t happen
Like Steve220 says Mintex 1144’s are much better
Posted 22 September 2019 - 03:40 PM
Posted 23 September 2019 - 11:35 AM
Yes it happened to me. The braking material had separated from the steel backing plate. Luckily it was held in place by the pistons and the pins at the front of the calliper. It MOTed fine and the braking had not been affected.
I am still a fan of EBC, tho.
Posted 23 September 2019 - 12:43 PM
Same here on an old M3 track car. They replaced them twice, but I gave up in the end and have never bought EBC since.
Also tagged with one or more of these keywords: brakes
Mini Technical Sections →
Problems, Questions and Technical →
Adjusting Brake Bias For 7.5" Discs With Pdwa ValveStarted by Daniel Watkin , 16 Nov 2023 brakes |
Answered
Fam7821 Brake Limiter Valve - Mounted Upside Down?Started by tarnofsky , 29 Sep 2023 brakes |
Kent 286 Can & MotStarted by frosty90 , 07 Sep 2023 brakes |
Brake Master Cylinder ReplacementStarted by M I N I , 30 Aug 2023 brakes |
Fitting 10” Wheels On My Mini Convertible (Spi)Started by Dalla , 29 May 2023 suspension, brakes |
