O,
Photo of Greg's Swiss Cheese.
Posted 02 October 2019 - 01:38 PM
O,
Posted 02 October 2019 - 06:19 PM
Posted 03 October 2019 - 12:48 PM
Sorry guys, no more holes today... Some work done on the gearbox. After deep cleaning, new roller bearings are fitted, with a straight cut gear set from Minispares (clubman type) :
Now I have to choose the correct final drive...3.65, 3.76?...
Posted 29 November 2019 - 01:13 PM
Body's back from sandblasting. Here are some pics from the sandblaster :
I've made some small plates to close rear of the inner sills, where companion boxes are originally located :
Also made a small bracket that will sits under the bonnet, to support fuel pump inertia switch :
And started to make 2 rear fiberglass bonnet brackets. They look huge on the pics, so I think that I will make 2 new ones, smaller :
Posted 28 January 2020 - 02:09 PM
Some bodywork done on the front end, as I needed some clearance for the big ITG foam air filter :
Seems that I will need some serious wheel arches!!
So, started to fit the arches with rivnuts :
Here is how it looks (Group 5 wide) :
And, as I needed a spare wheel, I asked a friend to make one for me :
Posted 28 January 2020 - 07:41 PM
Posted 28 January 2020 - 08:22 PM
Nice work! The gear shift mount brackets are very neat.
Couple of questions though...
Doesn’t drilling holes in the fan shroud compromise the duct effect?
What a different pattern to the centre of the spare wheel?
Nice touch with the fitting of the arches, should be very secure (probably better than bonding and certainly more serviceable).
Thx! Love the gear shift mount brackets too
Can't tell you if drilling holes in the fan shroud can affect the duct effect. I have seen this in a lot of race Mini's and loved the "lightweight touch" it gives to the engine ebay... As I have fitted an electrical aux. fan to the inner wing, I'm not so worry about this.
The spare wheel is different because a friend of mine designed and made it for me. You can even see on the second photo that he was kind enough to put my name on the wheel (laser engraved). This friend (FS engineering) also made the gear shift mount brackets.
Rivnuts are very practicals as they allow easy and multiple mount / dismount! Also fitted rivnuts to the front grill, front lights bowls, etc.
Posted 29 January 2020 - 07:31 PM
Posted 29 January 2020 - 08:38 PM
Clearly you work in a fabrication shop.. cracking stuff.. keep it up.. be a nice car this...
Thx for your comment! Actually... I'm a lawyer, but I'd love to work in a fabrication shop... or in a car body shop!
Just received the latest product from Specialist Component and love it!
Posted 29 January 2020 - 11:46 PM
How many holes do you plan to drill in that ?
Posted 30 January 2020 - 09:07 AM
WANT !!
Phil.
Posted 30 January 2020 - 04:26 PM
I feel alittle stoopid now...Thx for your comment! Actually... I'm a lawyer, but I'd love to work in a fabrication shop... or in a car body shop!Clearly you work in a fabrication shop.. cracking stuff.. keep it up.. be a nice car this...
Posted 10 March 2020 - 08:47 PM
Something new and stylish arrived ! What do you guys think about it?
Posted 10 March 2020 - 10:35 PM
Safety feature !
That should knock 5MPH off the top speed.
Posted 12 March 2020 - 09:46 PM
