96 K1100 Equinox
#46
Posted 22 April 2020 - 01:19 PM
#47
Posted 22 April 2020 - 03:57 PM
cant wait to see it at the meets!!! Looking well smart
Cheers Steve.
#48
Posted 28 April 2020 - 08:31 AM
Those Setrab coolers are superb quality. I see that Alchall has gone for one too.
#49
Posted 28 April 2020 - 08:22 PM
Yes, they are top notch, and a lot more efficient than the cheaper models, allowing me to go for a slightly small size. Going to make up a couple a brackets and mount it behind the front grill, pretty much the same as Alchall.
#50
Posted 29 April 2020 - 09:10 AM
Too nice to be hidden away behind a grill....
#51
Posted 30 April 2020 - 01:35 PM
This is how I am mounting mine, I'm plumbing it in via a oil stat which is part of a take off sandwich plate at the oil filter.
I'm using banjo connectors to save space, Setrab sell these but they are expensive, I got mine from Torques for half the price
#52
Posted 30 April 2020 - 04:20 PM
Such a mega thing, the noise must be incredible!
#53
Posted 30 April 2020 - 07:23 PM
I see you have turned your oil stat round, I take it there wasn't enough room to have the fittings facing forward. I got my cooler and Mocal stat from Merlinmotorsport, and some of my fittings from Torques as well, a fair bit cheaper, just hope they are reliable.
#54
Posted 30 April 2020 - 07:26 PM
Hope so Dougie, with the engine and straight cut drops, I think I might need ear plugs for long trips, or maybe still, just turn the stereo up, lol.
Edited by 72hump, 30 April 2020 - 07:30 PM.
#55
Posted 01 May 2020 - 08:41 AM
My stat is also from Merlin but it's a Setrab, it was a little more expensive, I have no logic for choosing it over the Mocal! it actually would only fit that way around but actually for routing of the hoses it would have had to anyway, if it could have fit at a different angle it might have worked if I'd gone with AN8 hose but the AN10 hoses I have used are quite bulky.
The Torques parts do seem to be good quality and seem to have very good reviews, time will tell I guess....
#56
Posted 01 May 2020 - 10:48 AM
I often drive with no music and just enjoy the engine noise
#57
Posted 27 July 2020 - 08:29 PM
Today, I got out to garage and started to strip the underseal of the fuel lines, which some numpty thought was a good idea. Very time consuming, so I've only managed to strip the supply/return line, and the short lines from the fuel filter. Will get the breather line done in the next few days, then get them all sprayed.
Hopefully by the end of the week I will get the chassis of the trolley and onto the axle stands so I can get underneath and get the fuel lines, brake pipe, and steering rack on.
#58
Posted 31 July 2020 - 09:00 PM
#59
Posted 24 August 2020 - 09:04 PM
Started on the rear subframe, I've had this sitting in the car for ages, I got this from one of the guys in IMOG, it was in need of attention. The old paint/underseal was stripped of, the metal was checked out, and rust cleaned up. It was given a good couple of coats of etch primer, then three coats of 2K black.
This afternoon I took a tap and die to clean out all the threads, and put on the red DSN trunnions, will hopefully get this onto the car by the weekend, this will free up some space in the garage.
