Clutch Housing - Upgraded Gasket To Avoid Leaks
2 replies to this topic
#1 mab01uk
mab01uk
  • 11,795 posts
Posted 05 October 2019 - 12:35 PM
Seen in November issue of 'Classics' magazine:-
Minispares now offers this upgraded gasket GUG705563GM to eradicate oil leals, as introduced by Rover in 1997 for the MPi Minis.
"Latest state of the art Klinger material gasket, replacing 22A2237B for the clutch housing to help prevent oil leaks. Measures 31 thou or 0.81 mm thick but compresses to correct size when fitted. Using latest gasket technology to eradicate leaks it is the best available not requiring any sealant and torqued to 18lbs per sq ft."
https://www.minispar...UG705563GM.aspx
Edited by mab01uk, 05 October 2019 - 12:36 PM.
#2 Rorf
Rorf
  • 857 posts
Posted 05 October 2019 - 01:48 PM
Pity I never saw that gasket before assembling my engine. The only gasket I did not use Hylomar blue gasket sealer on and now it is leaking there 200kms later - really annoying.
#3 imack
imack
  • 1,868 posts
Posted 05 October 2019 - 02:36 PM
Can't say I've ever had an issue with the standard one.
