Boot Subwoofer Recomendations
2 replies to this topic
#1 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,157 posts
  • Name: Sean
Posted 09 October 2019 - 05:34 PM
A mate is looking to fit a subwoofer in the boot of his car.  It needs to be one of the enclosure ones with a built in amp as it also needs to be removable.
It will also be fitted with a boot liner kit as well
Thanks in advance
#2 vx220
vx220
  • 419 posts
Posted 10 October 2019 - 05:11 AM
If a small amp can be fitted separately, that makes removing the sub much easier (just two speaker wires) and it's amazing how small some class d amps are now!
To remove an active sub you need to disconnect two speaker wires, up to four input wires, a power and a ground and a remote wire!
#3 BaronVonchesto
BaronVonchesto
  • 532 posts
Posted 04 December 2019 - 05:42 AM
If you're up for a bit of DIY check out Cole's boot subway box -
I second keeping the amp separate from the sub. You can mount it inside, under the rear seat.
by the way subway boxes are a whole science of their own, so if you're looking to get the lowest, tightest or loudest/boomiest bass possible you're probably going to be disappointed. Options are pretty limited for a mini if you want the boot to be usable.
