Here We Go Again
6 replies to this topic
#1 Lennyliverpool
Lennyliverpool
  • 329 posts
  • Local Club: northampton
Posted 11 October 2019 - 05:07 PM
So trouble free for nearly a year as a daily driver until today
Starts fine but sounds like a tank with reduced power
Dashpot has oil but noticed that the middle 2 ht leads when taken of and engine running dont have any effect at all engine remains steady - the other 2 leads do cause the engine tone to change
So new leads? Dizzy? - it's an electronic one
So will check in the morning
All good fun!
#2 richmondclassicsnorthwales
  • 942 posts
Posted 11 October 2019 - 05:13 PM
Hi
Have a look at the Cap, Rotor arm, electronic module, swap leads with another set or change them altogether if you know they are old - only a good thing for the future
Vacuum advance is working - suck on the tube - that is if you have one of course, fuel filter if you have one - and any LT leads
Just a few starting pointers
#3 panky
panky
  • 1,853 posts
Posted 11 October 2019 - 05:43 PM
I would suspect head gasket gone between  cylinders 2 and three. A compression test will confirm but it does sound like it.
#4 Lennyliverpool
Lennyliverpool
  • 329 posts
Posted 11 October 2019 - 05:55 PM
Did think about head gasket but no smoke may
#5 Lennyliverpool
Lennyliverpool
  • 329 posts
Posted 11 October 2019 - 05:56 PM
Mayo as I was saying!
Will check all other points in the morning
Still suspect leads - hopefully because it's cheaper!
#6 panky
panky
  • 1,853 posts
Posted 11 October 2019 - 08:37 PM
Swap 1 and 4 leads with 2 and 3 and see what happens. You won't get mayo if the break is between 2 and 3 because the water ways or oil ports won't have been affected.
I suggested this because exactly the same thing happened to me a few years ago and the symptoms were the same, hopefully I'm wrong and it's an easy fix.
#7 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 11 October 2019 - 09:21 PM
Head gasket 10quid stake pretty classic failure to be fair
