Edited by Jad, 15 October 2019 - 07:40 PM.
Help Needed
#16
Posted 15 October 2019 - 07:39 PM
#17
Posted 15 October 2019 - 07:47 PM
So from what you are saying you are buying the half floor panels, ie from front to back??
If that is the case then yes add some bracing. You will need to get into the companion bins as well to do this job properly so they will need to be removed.
#18
Posted 15 October 2019 - 08:39 PM
Yes I’ve checked in there and it’s completely rotten, is this part of the floor pan? I’m not worried about the work or welding just need to make sure I get it right. Yes I’m going to do one side full length at a time. It’s a shame as it’s only rotted we’re the over sill is welded to the floor, either side of the seam weld it’s fine.
#19
Posted 15 October 2019 - 09:05 PM
The inside of the companion bin is part of the floor / inner sill. Its not a small job what you are going to do and will take some time to do it correctly.
This is the end that attaches to the heelboard
Companion bin out
My internal bracing
Slaved in companion bin
Inner sill stiffener or companion bin closer and this is what the inner sill attaches to.
If you have a look at the Project Paddy link in my signature you will see all of this and it will guide you for what you need to do. I changed the inner sills to first flute on both sides as the floor was sound.
#20
Posted 16 October 2019 - 06:22 AM
