Can’T Move Mini
Posted 14 October 2019 - 10:42 PM
Posted 15 October 2019 - 07:23 AM
Probably handbrake if it's been left on. Jack up one corner at a time and see which wheel doesn't turn.
I take it the car doesn't run? They normally release with a clonk once you're moving unless it's really bad. Can you tow the car a few yards with another vehicle?
Failing that try removing the offending wheel(s) and smack the brake drum with a soft mallet or a hammer with a block of wood in between to soften the blow to see if that shocks the shoes free.
Posted 15 October 2019 - 07:52 AM
As said. A gentle tow with another vehicle is often enough to free the drums off.
Once, many moons ago with stuck rear drums on an old fiesta, and no other car or tools available. I jacked up the rear at each side and held it up on offcuts of cls timber, then shoved the car forwards off the timber.
I certainly would not recommend that! Rather stupid But it did work!
Posted 15 October 2019 - 09:49 AM
Posted 15 October 2019 - 12:26 PM
Posted 15 October 2019 - 12:27 PM
Posted 15 October 2019 - 03:54 PM
I had a similar problem with mine. It turned out to be the nearside front brake pads had locked on to the disc. I had to free them off removing the 2 split pins and jiggling the pads about
Posted 16 October 2019 - 05:23 AM
Rusty steel actually expands - if it has been left out in the weather for years then expect the worse.
Posted 16 October 2019 - 11:31 AM
Edited by jime17, 16 October 2019 - 11:33 AM.
Posted 16 October 2019 - 01:11 PM
I can vouch for that only not on car metal. Between close coupled cisterns and bowls is a steel plate that is used to hold the two together. I recently had to take one apart that was fitted about 18 years ago .. I know, I installed it.
The steel plate was at least twice the thickness of a new one and you could see the layers that formed the steel plate. It didn't take much to snap the thing in half either!
Posted 25 October 2019 - 09:48 PM
