1310 Breather
2 replies to this topic
#1 kiwi topcat
kiwi topcat
  • 31 posts
Posted 16 October 2019 - 06:47 AM
i have a 1310 with no breather from the timing chain cover. it had one on an original rocker cover and one at flywheel
i have fitted 1.5 rockers and changed rocker cover to a new alloy rocker cover.
i left off rocker cover breather as no where to install one. i thought the breather through the oil filler cap would be enough for a breather BUT no seems NOT as now clutch oil seal is leaking any ideas of how to fit a breather to alloy rocker cover
#2 nicklouse
  • 17,945 posts
Posted 16 October 2019 - 06:50 AM
you get someone to weld one on. or refit the steel pressed cover.
But note that the cap allows air in and it is extracted from the other breathers.
#3 Tupers
Tupers
  • 4,105 posts
Posted 16 October 2019 - 03:47 PM
You can either get a piece of aluminium pipe welded on or you could drill and tap it for a barbed hose fitting. https://www.pipestoc...e-threaded-bspp
You’ll just have to make sure you position it so the rocker gear doesn’t touch it.
