67 Cooper S Question
12 replies to this topic
#1 Chris.Williams
Chris.Williams
  • 679 posts
Posted 17 October 2019 - 08:45 PM
Attached File  6A4FBA1A-040F-4ED9-9D02-0B1C0A8BB1AB.jpeg   133.49K   20 downloads
Has anybody seen a radiator cowl on both sides before?
It looks very factory.
This car has also had a cage at some point.
#2 beardylondon
beardylondon
  • 1,802 posts
Posted 17 October 2019 - 09:18 PM
Drivers side cowl, so off side in UK, that has to be a post factory mod, never seen that before!
Edited by beardylondon, 18 October 2019 - 08:20 AM.
#3 Curley
Curley
  • 471 posts
  • Local Club: Not MINI friendly
Posted 17 October 2019 - 09:29 PM
Yup, that's perfectly normal on early cars, I think anything up to end of Mk3 twin bolt ish.
http://www.minispare...ck to catalogue
Edited by Curley, 17 October 2019 - 09:30 PM.
#4 timmy850
timmy850
  • 3,609 posts
  • Local Club: MITG
Posted 17 October 2019 - 10:34 PM
The second shroud on the RHS of the car is definitely not factory. Normally on a Cooper S the brake booster is bolted in there.
#5 Chris.Williams
Chris.Williams
  • 679 posts
Posted 17 October 2019 - 10:56 PM
No the other side. Drivers side of a RHD.
#6 Chris.Williams
Chris.Williams
  • 679 posts
Posted 17 October 2019 - 10:57 PM
That has to be a post factory mod, never seen that before!
Yes bit odd
#7 Chris.Williams
Chris.Williams
  • 679 posts
Yes very puzzling
#8 nicklouse
  • 19,066 posts
Posted 17 October 2019 - 10:59 PM
Yep that is LHs but fir the RHs?
#9 Curley
Curley
  • 471 posts
Posted 17 October 2019 - 11:05 PM
Gotcha, the way OP phrased it i thought he meant OSF. The one on the other side is not stock but does look very well executed.
#10 Spider
  • 15,871 posts
Posted 17 October 2019 - 11:55 PM
It's not factory, specially in a Cooper S. They all had Brake Servos fitted there.
I've seen it people think they need a second radiator and do a similar Body modification to accommodate that.
There's no listing in any of the parts books for it and equally, there's no mention in any of the Special Tuning booklets.
Just a few other things I can see from that photo, there is many other things that have been messed with there, so, this is just another of that list.
#11 Chris.Williams
Chris.Williams
  • 679 posts
Posted 18 October 2019 - 12:07 AM
Just so I’m aware, would you mind pointing out what you see that isn’t correct?
#12 Spider
  • 15,871 posts
Posted 18 October 2019 - 04:41 AM
Many I think are obvious, but I'll list them just the same;-
Weber,
Fuel Pressure Regulator,
Dry Suspension (should be Hydro),
Brake Servo s either missing or located elsewhere,
Washer Bottle, type and location,
Radiator,
Rubber around the Radiator,
Fan Shroud,
Alternator (should be Dynamo),
Rocker Cover,
Fan * I think, can't quite see it to be 100% sure * should be 16 blade steel type,
Crankcase Breather - which also leads me to say it's probably not an S Block,
It appears to have a 12G940 head (should be an AEG163),
It also appears to have the wrong Heater Take Off / Valve (can't quite see it to be sure),
Bulkhead Soundproofing,
I can't quite see to be sure, but the wiper location on the windscreen scuttle looks later than 67,
Although it's had that custom inner wing fitted, the bonnet stay locator is missing and could have been fitted,
That's about all I can see.
#13 nicklouse
  • 19,066 posts
Posted 18 October 2019 - 06:59 AM
and the 11th bolt is now a stud and nut.
