Next problem on the list, clutch hydraulics!
I have the slave cylinder out, fluid drained etc etc. Since I have been having some very slight clutch issues(along with a leaky master cylinder) , I decided to replace all the clutch bits I can without pulling the engine. How on Earth do I get the clutch pushrod cotter pin out? The pushrod (that goes into the slave) has some play, I have a new one ready( along with a new pin to hold it into place) however the split pin at the rear is impossible to get at and remove!!!
Furthermore I get the impression that the pin itself is jammed in place and then I won't be able to punch it out because there is simply no room!
Any input?
Edited by Coolingthunder, 19 October 2019 - 05:17 PM.
