Any Dellorto Experts Out There?
8 replies to this topic
#1 Henrik Larsen
Henrik Larsen
    Just On Tickover
  • 5 posts
Posted 19 October 2019 - 05:15 PM
Hi
I have a 998 with a stage 1 kitt fitted, 12g940 head, kent md266 cam and a lightened std flywheel. I want to fit a dellorto dhla 40 g carb that i have had sitting in a box for a couple of years... Does anyone have an idea how i should spec this carburator?
Sorry for the bad soelling and gramma. English is my third language.
#2 nicklouse
  • 17,945 posts
Posted 19 October 2019 - 06:27 PM
Third language. I found English was Most Swedes Second.
personally I would not fit that carb never liked the Delortos on a Mini.
but I would start with Vizzards 998 specs modified head semi race cam and extractor exhaust
choke 32, main 145, air corrector 200 ,pump jet 40, idle 55, Aux Venturi 4.5
as a starting point
#3 sid trunley
sid trunley
  • Validating
  • 23 posts
have u got the inlet manifold?
#4 Henrik Larsen
Henrik Larsen
    Just On Tickover
  • 5 posts
Posted 19 October 2019 - 06:42 PM
as a starting point
#5 Henrik Larsen
Henrik Larsen
    Just On Tickover
  • 5 posts
Posted 19 October 2019 - 06:54 PM
#6 Henrik Larsen
Henrik Larsen
    Just On Tickover
  • 5 posts
Posted 19 October 2019 - 07:00 PM
The replybutton does not seem to be working.
I'm born Danish, so swedish is my second language?
Yes, I do have the inlet manifold.
I'm thinking the dellorto would be more reliable (easyer the deal with) than twin SU's?
#7 nicklouse
  • 17,945 posts
Posted 19 October 2019 - 08:03 PM
Damn some people have all the luck. I have Danish family and lived in Sweden for 11 years.
 It back to the question. Ok I would run the delorto instead of twins. But I would run an HIF in preference to either.
there often seems to be an idea that if it is standard it can’t be that good. Unfortunately on the Mini there are a few things that are actually very good. And the last HIF carbs is one of these.  Which HIF depends on what power you expect to get. Going too big can reduce power through lower gas speed in the carb and inlet manifold and head ports.
 It if you have the 40 use it it will work but I hope the manifold is suitable and you have modified the bulk head to allow suitable ram pipes and filter. If the inlet is short and you don’t have the room for ram pipes the don’t bother with it.
#8 cal844
cal844
  • 9,488 posts
  • Local Club: TFMOC
Posted 19 October 2019 - 11:05 PM
I use HS carbs all the time, HS4 is a great carb, the HiF 38 is even better,more fuel efficiency was gained.
Keep it simple
Edited by cal844, 19 October 2019 - 11:05 PM.
#9 timmy850
timmy850
  • 2,997 posts
  • Local Club: MITG
Posted 21 October 2019 - 05:59 AM
I like Dellortos. I had one on my near stock 998 and it worked great - same carb with some tweaks is now on my modified 1098. They are easy to tune as each different part tunes a different part of the fuel curve.
I used:
32 choke
155 main jet
180 air corrector
45 idle jet
7772.5 emulsion tube
I’d suggest getting an air fuel ratio gauge so you can make informed choices when tuning (or pay for a dyno session). There is a good book by Des Hammil on Dellorto and Weber tuning that’ll teach you how to tune them
Edited by timmy850, 21 October 2019 - 06:00 AM.
