filling pannel lines!
miniman5
, Aug 12 2004 06:51 AM
8 replies to this topic
Posted 12 August 2004 - 06:51 AM
Hello the time is nehe or how ever its spelt! ive got all the rust of the back and and have sprayed it up dad still ses its no good even tho i was in thge garage till some god forsaken hour again! but its ok because she needs loving! i was wondering when i do the wing u no theres a line where the wing meets the scuttle aint there? and theres one under the head light! would it be ok to fill then? just to make it look that little bit more differant? heres the rust in the one wing and the line im on about (i chould think cowboy knows what im on about! he is clever ) not saying u lot aint or n e fin :tongue: ok im sure u lot no where i mean!
Posted 12 August 2004 - 07:36 AM
he he im mad! i just bin out to the garage in my pj's one of teh old bids nxt door saw me n e way i recon those lines trap the water and help th ewater collect there hence thats why the always rust there!!!!!!! few! im clever!! umm.. i am right aint i??
Save The Wales!! :wales:
Posted 12 August 2004 - 08:32 AM
the line your on about is the panel join, you can clean them up and then use bodyfiller to make them smooth, before respraying, a word of warning, there is a possabitity that after you have done this, with vibration, the filler could come loose after time, leaving it worse.
as for the rust, it does seem that a lot of mini's rust in that same spot, after you have cleaned it up and resprayed it, don't forget to put some kind of underbody sealant on the inner wings, id tend to say that this is probably where the water is getting in first, then staying moist, and eating away at the metal.
the choice for filling the joints is up to you
Posted 12 August 2004 - 12:30 PM
I wouldn't expect that Minis rust in different spots in the U.K. than they do here. As Cowboy said, the joint at the scuttle is a place that will crack open and if filled improperly will collect more water. Scuttle/wing rust like what you're showing in the pictures doesn't just come from the top down... it also comes from the inside out. You may find when you start removing the paint around the seams that you've opened up a can of worms that you can either fix correctly with new metal or bodge with Bondo from the top. It's a question of how much money and time you want to spend. Fill and smooth that seam if you insist, but following a proper rust repair that joint should be filled with paintable seam sealer so it can flex.
Posted 12 August 2004 - 06:20 PM
so use seam seler isntead?
Posted 12 August 2004 - 07:21 PM
I would use seam sealer in that joint but it's up to you. You said you wanted smooth looking seams and seam sealer will leave the little groove. Regardless of what you do you'll first need to pick out all the old sealer in the gap and if you're not replacing the panels you'll need to chemically treat the rust trapped there. All that bubbling rust you see on the top of the wing below the scuttle will need to be removed, scraped down to bare metal and filled as necessary. Anything less is a waste of your time and effort as it will come back in very short order.
Posted 12 August 2004 - 09:21 PM
ohh C**p.... el well its sumat for me to do and some practice ive got the bubberling out now its jsut rust now and THERE IS NO HOLE!!! i was like HOLY C**p! :tongue: bit tis ok now! guna crack on with it tomoz
Posted 13 August 2004 - 12:24 PM
eye wich u wood step writin lyke thet becus eye kent undrstan u eye shooodn hav 2 spen five meeneets readin one centunce u wrot sew eye ken understan it it aint cute, its annoyin
Posted 13 August 2004 - 01:13 PM
oww! sorry!
