Engine Bay Clean Up Now Car Won’T Start (96 Spi)
Posted 22 October 2019 - 08:10 AM
Very confused what’s wrong with my car. I was cleaning up my engine bay with a new bit of paint , ignition coil , rocker cover etc. The car was running perfect prior to this and then for the last week and a half / it had been sitting in my garage with the ht leads / alternator disconnected while I worked on it. It’s a 96 spi.
The car turns over but won’t fire, sounds like it really wants to go but just never makes that final start. The only real new bits that could cause issue has been the ignition coil but I put the old one back on and still wouldn’t fire. I checked the positive side with a meter and am getting 12.5 volts ..also put a power pack on the battery so I think the issue is either fuel or electrical.
Haven’t done anything so confused why all of a sudden it’s acting up and won’t start.
Any help appreciated.
Thanks,
Mark
Posted 22 October 2019 - 08:12 AM
Check your HT leads are in the right order.
Posted 22 October 2019 - 08:40 AM
Check the Fuel pump is working as it should
Posted 22 October 2019 - 09:45 AM
Hi all,
Thanks,
Mark
you say you did nothing. sorry wrong. you disconnected things. so check those first then back to basics. fuel- spark etc
Posted 22 October 2019 - 01:02 PM
Posted 22 October 2019 - 06:26 PM
Posted 23 October 2019 - 06:20 PM
Posted 25 October 2019 - 02:41 PM
Also tagged with one or more of these keywords: electrical, engine
Mini Technical Sections →
Problems, Questions and Technical →
Piston Rings - A-Series 998 Engine - Help RequiredStarted by WanaGo , Yesterday, 07:59 AM engine |
Exhaust Choice 45Dcoe - Rc40?Started by lachlan1275gt , 13 Apr 2024 engine |
1071 Main Bearing Caps.Started by 246jaenick , 02 Apr 2024 engine |
Misfire - Ignition Fault Or Fuel Problem?Started by derekaka2sheds , 01 Apr 2024 electrical, engine |
Which Rocker ArmsStarted by mark the diver , 30 Mar 2024 engine |
