Carb Fuel Line Advice
Best Answer cal844 , 22 October 2019 - 06:48 PM
Just measure the carb throat it'll be close to 38 or 44 mm Go to the full post
13 replies to this topic
#1 Indy495
Indy495
  • Just Joined
  • 47 posts
Posted 22 October 2019 - 03:49 PM
Hi again mini peeps
I am in the process of fitting the carb back on the manifold.
I didn’t take it off, so I’m a bit unsure of what goes where.
Can you let me know what goes onto the three inlet/outlet pipes on the carb
Also can anyone tell
Me which type of carb this is as I has read about different ones being fitted.
It’s a 1992 1275.
#2 gazza82
gazza82
  • 2,917 posts
  • Local Club: TMF+
Posted 22 October 2019 - 03:59 PM
It's a HIF carb nut not sure if it's a HIF38 or HIF44
This help? This is an HIF38 ...
Attached File  HIF 38 carb connections.jpg   28.19K   3 downloads
Edited by gazza82, 22 October 2019 - 04:02 PM.
#3 Indy495
Indy495
  • Just Joined
  • 47 posts
Posted 22 October 2019 - 04:45 PM
Thanks gazza82
that has 4 tubes coming from it and appears different to mine.
I reckon the fuel in is the same, but still not sure of the others.
my rocker cover doesn’t seem to have any inlet ports in it either.
thanks again
#4 Maccmike8
Maccmike8
  • 1,089 posts
Posted 22 October 2019 - 04:47 PM
I think the others are the same too - excluding the open/extended?
#5 Indy495
Indy495
  • Just Joined
  • 47 posts
Posted 22 October 2019 - 05:15 PM
Bit more internet searching and I think I’ve got the answer.
thanks again.
#6 Indy495
Indy495
  • Just Joined
  • 47 posts
Posted 22 October 2019 - 05:16 PM
I reckon mines a Hif44.
#7 cal844
cal844
  • 9,488 posts
  • Local Club: TFMOC
Posted 22 October 2019 - 06:48 PM   Best Answer
#8 Ethel
  • 25,416 posts
Posted 23 October 2019 - 11:35 AM
The one the screw's pointing at is the  overflow/ float chamber vent. The lower one, when the carb's the right way up is the fuel inlet and the big 'un is for the crank case breathers.
The extras on Gazza's piccy are a cruising fuel economy device and would be linked with a short length of hose.
Look at the filter mounting face to tell a 38 from a 44. The 38 has a pointy bottom
https://encrypted-tb...OguhZMu1ZZeNlYg
#9 Indy495
Indy495
  • Just Joined
  • 47 posts
Posted 01 November 2019 - 09:50 AM
Thanks mini experts.
mine is a hit 38. I have measured it.
carb now in position on manifold and awaiting braided fuel lines.
cheers for all the help
#10 nicklouse
  • 17,945 posts
Posted 01 November 2019 - 09:55 AM
sorry not the best idea. as you have no idea what condition they are in as you can not see them. modern fuel eats many rubber hoses. the ones that seem to fail the most are bought via ebay.
keep an eye on them.
#11 sonscar
sonscar
  • 2,724 posts
Posted 01 November 2019 - 01:46 PM
I agree having had both stainless and cotton braided hoses fail bought from a local hose supplier.Steve..
#12 Ethel
  • 25,416 posts
Posted 01 November 2019 - 03:02 PM
HIF - horizontal integral float
#13 cal844
cal844
  • 9,488 posts
  • Local Club: TFMOC
Posted 01 November 2019 - 09:10 PM
I use fabric braided fuel line, its loose braid available from a few suppliers but I use McGill motorsport here in Scotland
Support local when you can
Edited by cal844, 01 November 2019 - 09:11 PM.
#14 croc7
croc7
  • 752 posts
Posted 02 November 2019 - 09:23 PM
Barricade fuel line by Gates. E85 compatible.
